Cannot get Daz installer to download studio.
"the path specified in the "package archive" field on the "Downloads" page of the "settings" dialogue, is not currently available. make sure the drive is connected to your computer and that the computer recognizes the drive, then try again."
Did install on C: drive. Have tried downloading and deleting the whole app six times at this point. Have restarted several times too. Not sure how to get started.
1227 x 668 - 30K
  • crosswindcrosswind Posts: 10,351
    edited September 2025
    Click the gear icon in the upper right corner of DIM > Advance Setttings...> Downloads tab, check if the path you set in Package Archive is correct. If it's on an SSD, check if the SSD is stably connected to your PC / laptop...
    Post edited by crosswind on
  • As best I can understand, I have done things like this around eight times. Trying again this morning. Tried seeing if it would work on an old laptop, and it zipped right through to downloading. Would use the laptop, but it consistently crashes every few minutes, which is understandable for a twelve year old machine.
  • You can copy the downloads across from the old laptop to the folder set for DIM's downloads on the other machine. Then  after restarting or refreshing DIM they should be in the Ready to Install tab.
