BW Classy Vision Eyewear Set for Genesis 9, missing data from morphs
Hello,
I'm speaking about the BW Classy Vision Eyewear Set for Genesis 9 by @Beautyworks.
When I tried 'BW CVES Glasses 02', I wanted to use the various adjustment morphs it is supposed to have to get a better fit on a character, but regardless of which morphs I was using, I saw no change at all on the glasses.
After checking that I was wearing my own glasses, I opened the Geometry tools, switched it to Vertex mode, then put the Parameters tab in Edit Mode to 'Select Morph Vertices' and, well, a whole lot of nothing happened.
I did re-check my glasses, and downloaded the package from Daz3D.com to get a look at the content of the .dsf files of these elusive morphs and while they are not empty, compared to the morphs from all the other glasses of that product, none of the adjustment morphs from Glasses 02 include data about delta. They are also all weighting around 1 kb.
Can someone who has the product check that I'm not particularly unlucky and see if they have the same problem with their version of this product?
  • The morphs seem to be empty, if you open the .dsf files in a text editor then the vertex count is 0. Please report this as an issue to Technical Support.
