Can't get SY Essential Creature Morphs to work
Is there a basic set of steps or link to use SY Essential Creature Morphs to work? I can apply to shell, but nothing else seems to load or work.... I can't find it under parameters or shaping.whether I select the figure or the shell. Help?
Thanks
  • crosswindcrosswind Posts: 10,299
    edited September 2025
    Well, it's a unique case... as the creature morphs belong to different paths under Actor.
    You can: firstly load a G9 Base figure, in Parameters pane, if you use DS 4.22+, paste this string: present::color::a::r::128 && present::color::a::g::255 && present::color::a::b::0 && rx::SY into Filter Field (Save it as a Filter for frequent use...) or just type in rx::SY.*
    Then you'll see all creature morphs from this product in property list.  Dial the morphs you want. Load the geoshell as well as their Hierarchical Material Presets as you did before.
    2560 x 1392 - 917K
    Post edited by crosswind on
  • Thank you very much crosswind! It worked perfectly!
