Manual Install Not Working Despite Following Instructions
Hi, I have a problem.
I've got some files I want to install manually but I don't see them pop up in my daz studio program once I do. Before you ask, I've followed the install instructions to the letter.I noticed I have 2 content directories from the manager in daz studio, but I've put the one I want to use at the top.
I think the problem is that by just dropping it in the library map on windows, the "InstallManagerFileRegister.json" doesn't get affected. I want to try and manually add the path of the new files in the .json but I'm not sure what the numbers at the end mean exactly and which ones I should put there.
For example: [ "runtime/textures/west_park/wp_dway_s_wall_t.jpg", 3 ],
I'm not sure what the 3 means here. Some entries have the number 2.
Thanks in advance for the help
  • The Runtime (except fdor specific library folders under Poser Formats) and Data folders do not have user-facing files and are hidden, if you can see those folders in the Content pane then you have not installed correctly (probably your unzipping included a folder like Content or My Library that you placed in the actual content diectory when it is actually a placeholder for the content directory you are using).
  • jjoynerjjoyner Posts: 884
    When I download a zipped folder that I plan to manually install, I always unzip it first.  I have seen videos that promote just left clicking and dragging the zipped folder to your Daz Studio library and then choosing Extract from the menu.  However, I like to first choose what I drag and drop to my library.  I don’t keep a ReadMe folder or a Documentation folder in my Daz Studio library.  If a ReadMe folder or a Documentation folder is in the unzipped folder, I save anything useful that is there (oftentimes, nothing that I need or want) in a Documentation folder that is not in my Daz Studio library.
    I manually install to a second content drive all of the content that I install via DIM as well as all third-party content that is not installed via DIM.
    I like using Smart Content in addition to the Content Library tab, so I also create a product from the files in the Content Library (one-step operation) so that I have the files in Smart Content as well.  The Smart Content entry won’t have a thumbnail image but that is easy to create.
