problem with interface
Hello,
I get this bug that happens with my left side panes. When I open the tabs, the tabs open cut off, so I cant access the numbers on the right, and the tabs no longer show so the pane can not be closed. I keep having to reset my workspace, which get annoying. I attached images. Is there a fix. Thanks
720 x 395 - 47K
720 x 372 - 49K
  • That usually means one of the docked panes has a minimum size that is larger than the available space, though with the reduce image size I am not quite certain what is docked where (you should be able to attach fuill-sized screenshots).
  • felisfelis Posts: 6,656
    It looks like there is timeline, and I assume that that is the culprit.
  • rfarainorfaraino Posts: 0
    edited September 2025
    Yes, the pane is larger than the space. If I undock the viewport the hidden pane tabs are behind it. How do you set the minimum size? Though it's buggy. if I refresh enough times the panes open fine, then all of a sudden they dont.
  • You may simply be trying to fit more into your available screen width than will fix, and depending on which panes are active in each well there may be underlapping. I don't think this is a bug per se - just asking the application to do something it can't.
  • It doesnt seem like my replies are posting. Yes, my panes are openning too wide. They dont need to; there's plenty of room
  • It was working all day just fine. Something is bugging the left side. See attackment
    720 x 384 - 43K
  • So what I did was I relaoded the CityLimit layout, made some minor tweaks and saved over my old layout preset. It seems to be fixed now. Thanks for trying to help
  • Please stop posying downsized screenshots, it makes them much harder to read. Since you didn't post images of the revised layout we can't see what the difference is.
