Do Hexagon tools even work???
I'm trying to do what should be a simple Boolean operation. I select my first object (a cube I created in Hexagon), select Boolean from the Surface tools palette, then select my second Hexagon created cube. Nothing happens. Doesn't matter if I hit the Enter key or click the Accept button. In reviewing the manual, I don't see anywhere a Tool Propties box with a Validate button, nor do I see any -/+ to view the different Boolean options. What am I missing?
  • StezzaStezza Posts: 9,277
    it should be straight forward
    create first cube
    create 2nd smaller cube and move it into the the first cube
    with smaller cube still selected select boolean from the menu then click on the larger ( first ) cube
    done..
    cool
    656 x 483 - 44K
  • NovaNova Posts: 365
    edited September 2025
    Hexagon sometimes hangs, change the perspective of the object and try again.
    It is also important that you use the current beta version, as older Hexagon versions had issues.
    831 x 213 - 21K
    1360 x 791 - 119K
    Post edited by Nova on
  • Thank you. Later, after I posted, I somehow (accidently) got it to work. But I will check what version I have.
  • Roman_K2Roman_K2 Posts: 1,277
    Wow, that is a cool illustration, Nova!  Medical illustrations who specialize in dentistry manuals would have a field that with this sort of thing. laugh yesyes
    Also, per the OP's question - I thought that the Enter key serves as validation?
