Is 2025 Downloadable?
ggs_26de60e5b2ggs_26de60e5b2 Posts: 114
Is it possible to download studio 2025?
In my Library it shows it as 'Inactive'?
There is no where it says 'Download'.
Post edited by ggs_26de60e5b2 on
  • At the moment it's only available through DIM.
    Which is why I've not yet played with it. I'll do a manual download, however a DIM install is something I can't (due to PC being unable to contact the outside world due to thickness of walls) and won't do.
    Regards,
    Richard
  • Inactive has nothing to do with downloadable, it means it is not listed as a product in the store. You will see the same on older products that you have purchased but which have been removed from the store.
  • crosswindcrosswind Posts: 10,281
    DS 2025 Alpha still belongs to Public Build channel. Public Build can only be downloadable and installed via DIM... so you have no way to find it downloadable in your Product Library other than Inactive.
  • Thanks all.
    So, how do I download it?
  • ggs_26de60e5b2 said:
    Thanks all.
    It should be available in DIM, if you don't see it make sure the Download filters are set to include the alpha.
  • barbultbarbult Posts: 27,527
    edited September 2025
    Illustration of selecting the necessary download filter in DIM.
    850 x 652 - 91K
    Post edited by barbult on
  • Thank you.
  • Thanks again
