Jepes Flying Veils
Once again a product I have purchased  with no intructions! Sure there are plenty of poses and props but how do you parent and shape the veils to Genesis 9. DAZ How about making sure all merchants include instructions with all products. Cheers
  • To parent, go into the scene tab, select the veil in use and drag it to the g9 figure name.
    Alternatively you can right click on the item and select Change "(name)" parent and in the popout menu select the Genesis 9 figure from the list and click accept. You can do this in the Scene tab or in the Viewport tab.
    Each of the veils has a set of morphs that change the shape to conform to the corresponding pose.
    Veil 1, for instance, has 9 different morph sliders in the Parameters or Shaping tab that change the shape and works with pose 1 only.
  • I have tried all the suggestions and none of them work! Cheers
  • crosswindcrosswind Posts: 10,347
    Check the instruction of how to use the product on Daz Wiki : http://docs.daz3d.com/doku.php/public/read_me/index/91102/start
    Not all vendors give instructions to their products but you always can check the products ReadMe on Daz Wiki. Better install a Daz-Deals add-on to your Browser, then you can directly jump to wiki page from the product main page.
