LI dForce Shower Tress Hair for Genesis 9 Problem
Hey,
when i attach the hair, and want to add a material / color, it says does not work
Someone has a answer to this?
Best wishes
  • crosswindcrosswind Posts: 10,249
    No issue on my side ~ What message did you get ?
    The material presets are all hierarchical material presets, you can either select G9 or hair nodes to apply the hair color ~
  • What's the specific error message?
  • I get this message all time....
    "An error occurred while reading the file. See the log for more details"
    Attached image too.... someone can help?
  • Image removed as it was not ToS compatible.
    Usually that means you are applying a preset (setings) without a target (a thing with settings to be changed) selected - check the end of Help>Troubleshooting>View Log File after getting the error for a bit more information about the precise issue.
