Daz3d 2025 alpha not using My 5070 Gpu
I have i5 1600kf and Giagbyte 5070 and when I try to render a scene , my gpu utlization stays below 5% and cpu utlization spikes upto 100%.
I tried everthing from slecting the GPu rendering only and every possible solution comes on internet.
  • What driver version? How are you assessing usage - Task Maanager is not reliable. If the CPU is also seelcted as a renderer in the hardware tab of Render Settings then the 100% is expected - try deselecting it, uncheck CPU Fallback, restart DS, and see what happens if you render.
  • crosswindcrosswind Posts: 10,356
    Install GPU-Z so as to easily monitor VRAM Usage (by MB).  Also check you DS log, it can clearly tell you if you run out of your VRAM ~~
    If you did run out of VRAM, GPU Load would be under a small % ~~
