Starlight Gauze body suit from the VYK Starlight Gauze Dress makes the Genesis 9 model disappear
[Starlight Gauze body suit from the VYK Starlight Gauze Dress makes the Genesis 9 model disappear] It's exactly as the title says. I simply click to load the body suit and the Genesis 9 model disappears except for the eyes and the mouth, as you can see. Does anyone know what may be causing this and how I can fix it?
1919 x 1013 - 598K
  • You probably need to hae a Geoemtry Shell applied to the figure, the the Bodysuit materials preset hides the unneeded parts and sets the remainder to look like fabric. Check to see if there is a preset (a Wearables preset, except you don't have any of the emtadata showing to guide you) for adding the shell first.
  • crosswindcrosswind Posts: 10,289
    If you installed the product via DIM, you would easily see you loaded a Material Preset on G9 rather than the bodyshell ~~
    Also check the Hint ~~
    2560 x 1392 - 1M
  • Thanks for the comments. When I get home I will try to apply what was said here.
  • edited August 2025
    I selected the Sexy Skinz Base and it worked. Thanks a lot!
    Post edited by Paleo Miles, the Paleo Knight on
  • Hey guys, sorry to ask for too much help but I have stumbled upon another issue, this time with the DAZ to Blender bridge and the Dragonhide Delta Loadout for Genesis 9 Daz to Blender Bridge issue with Dragonhide Delta Loadout for Genesis 9 https://share.google/gefSw5d8yPq51jokD I really want that model to work on Blender so I would appreciate some help and no one has replied to the thread yet when usually people would have replied already at this point so I am posting about it here. Hope you don't mind.
  • felisfelis Posts: 6,529
    You could try asking in the blender forum.
    But I would expect that they will recommend you to use Diffeomorhic to get your files into blender.
  • Diffeomorhic? Never heard of it but thanks for the suggestion. I'll check it out.
  • I tried Diffeomorphic out and it worked perfectly. Thanks a lot for the tip!
