New update messed up the camera!
I am unable to add a camera to a scene! (I am able to add a camera to a new/empty scene but not to a already made one) I get a Input Error saying A node labeled "Camera" already exists in the scene. Adjustments have been made. Verify the adjustments and try again.
This happened after the new update. Please help! How do I fix this!
422 x 315 - 31K
  • felisfelis Posts: 6,604
    If you have a camera (named Camera), it should normally just add a number.
    What happens if you give the created camera a different name and label?
    But I don't know why it can happen.
  • almahiedraalmahiedra Posts: 1,374
    Meanwhile, Shader Mixer is generating cameras instead of assigning shaders to surfaces
  • crosswindcrosswind Posts: 10,347
    You cannot add a camera with the Label that already exists in the Scene. DS detects the Labels from existing cameras and automatically add a suffix number to the newly-created one. If you manually type in a duplicated Label, it'll pop up that error message ~~
  • There is no camera in the scene but it still saying that is one!
  • Something in the scene causing the camera to mailfunction. I am making a colonial marine and I noticed that with some of the characters, for some reason the camera won't work. Not sure what causing this but it's very annoying. Any ideas?
    1173 x 1205 - 124K
  • I figured it out! The issue is the tactical helmet! When I removed the helmet (male of female version) the camera came back! I'm not sure why the helmet causing this but if someone knows something please advise. Thanks.
  • Does the helmet have a camera parented to it?
    edited August 2025
    Okay, the helmet has a sub-node Named and Labelled as "Camera".
    You can modify them in Joint Editor... as e.g. "Helmet Camera". Then Add Camera...(4 the first time...) will work with no warning message ~~
    2017 x 1290 - 223K
    2018 x 1330 - 268K
    Post edited by crosswind on
  • Where can I find this window?
    Select Joint Editor Tool, select the Camera bone in Scene tab, and rightclick in viewport Edit > Rename Node.
  • I don't have a "rename node" when I right click in the scene tab on the camera after selected Joint Editor tool.
  • The only node I see is reorder.
    Right-click in Viewport rather than Scene tab ~~
    2029 x 1133 - 224K
  • Thanks felis, I got it!
  • Thanks crosswind, I got it!
