How to find a duplicate formula?
Log
Previous:
File: /data/Daz 3D/Genesis 8/Female/Morphs/Angel - Wings/Youth Muffin/Youth Muffin Lower Arms.dsf
Owner: Genesis8Female
Input URI: Genesis8Female:/data/Daz%203D/Genesis%208/Female/Morphs/Angel%20-%20Wings/Youth%20Muffin/Youth%20Muffin%20Lower%20Arms.dsf#Youth%20Muffin%20Lower%20Arms?value
Input: Youth Muffin Lower Arms
Output URI: lThigh:/data/DAZ%203D/Genesis%208/Female/Genesis8Female.dsf#lThigh?end_point/x
Output: xEnd
Duplicate:
Output: xEnd
In paths
there is not a single difference.
I don't understand how to find a duplicate formula?
  • crosswindcrosswind Posts: 10,324
    There're two typical cases in terms of duplicate formula error: 1) Two or more Modifier assets (DSF files) have the very same URI ID; 2) Two or more very same URI formulae are saved within one Modifier asset.
    The case you have is the latter. You can simply open Youth Muffin Lower Arms.dsf file with Notepad++, delete the coding blocks of the duplicate formula(e), i.e.
    Search by: lThigh:/data/DAZ%203D/Genesis%208/Female/Genesis8Female.dsf#lThigh?end_point/x  You should be able to locate two lines, then delete one coding block of them, starting from { to },
    Save the DSF file. Reload G8F.
  • zeni1agentzeni1agent Posts: 76
    I tried to open the file Youth Muffin Lower Arms.dsf with my Notepad++ but I got unreadable text.
    Daz files are compressed by default, you'll need to decompress the file to open it in notepad.
    You can use the "Batch convert" tab in studio to decompress the file and open it in notepad++
