Values between keyframes change in a weird way.
ppaawweell336ppaawweell336 Posts: 26
Hello, I have a problem with keyframes on the timeline.
Let's say I have a total of 100 frames. The keyframes on the bones are set every 10 frames, so the keyframes are at 0, 10, 20, 30, and so on.
The animation looks smooth, except for the left arm, lef forearm, left collar. The values change in a strange way. Let's say that between frames 20 and 30, the values do not decrease gradually from -15 to -30 but are all over the place.
Key 21 is -15.20, Key 22 is -14.30, Key 23 is -17.50, Key 24 is -10.20. You see the problem.
The rest of the body is fine. Why is this happening? What could be causing it? The character is Genesis 8.1 Female
I would like to point out that I am transferring animation from Rokoko motion capture using the Mocap Live plugin. However, I don't think this is the cause of the problem, as all other characters work flawlessly and the problem only affects this particular character.
Post edited by ppaawweell336 on
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,712
    by default DAZ studio does not use linear tweening, it drives me nuts too
    you need to manually change it for every tweener
    it also does not keyframe everything along the timeline but importing a BVH it likely does but the rotation method, dual quaternion, might be different to the one the BVH uses, likely angles
  • ppaawweell336ppaawweell336 Posts: 26
    edited August 2025
    I know, I always switch to linear.
    I also do not upload BVH, but stream directly from Rokoko using Mocap Live plugin from Daz store. It works perfectly with every other character, the issue is only with this one character arm. There's always a problem with that arm no matter what animation I do. The other bones are totally fine.
    I'm not sure how this is possible, since the values should transition smoothly between keyframes, rather than jumping like that.
    yeah, I don't have the plugin or a Rokoko suit wink
    I was just going by the issues I have with BVH
  • http://docs.daz3d.com/doku.php/public/software/dazstudio/4/change_log_4_22_0_19#4_21_1_102
    Extended DzScene public API; added setDefaultKeyInterpolationType(), getDefaultKeyInterpolationType(); added defaultKeyInterpolationTypeChanged() signal
    https://www.daz3d.com/forums/discussion/comment/8934041/#Comment_8934041 has a script, demonstrated here https://www.daz3d.com/forums/discussion/comment/8950546/#Comment_8950546
    I just purchased a Rokoko Smartsuit Pro with gloves. Previously I tried to use the Mocap Live plugin to livestream with only the gloves and I could get the Genesis 9 fingers to work correctly. Considering giving it another shot. Do they work for you. How about Genesis 8 hands?
