Mirrored Hair Styles
Isn't it quite easy for an artist to create mirrored versions of his product?
For example I would like so much to have the wonderful Victoria 5 Elite Ponytail Hair parted conversely.
  • chris-2599934chris-2599934 Posts: 1,984
    If you select the hair before fitting it to the figure, and then set the X Scale to -100% (you might need to show hidden properties first) it will give you a mirror image. This seems to confuse some of the morphs, but otherwise seems to work.
  • I would love to have mirrored hair styles, to be able to choose part left or right, ponytail left or right and so on. . .
  • If you select the hair before fitting it to the figure, and then set the X Scale to -100% (you might need to show hidden properties first) it will give you a mirror image. This seems to confuse some of the morphs, but otherwise seems to work.
    You are right that this will work sometimes, but on other occasions it will cause the hair to seat/fit partially off or inside the head.
  • WolpiWolpi Posts: 323
    edited March 2016
    Thank you Chris, I experimented with this possibility before, but at least in the case of my favorized Victoria Ponytail Hair it's only possible to scale the x-dimension of the tail but not that of the main hair.
    But I found another strange way to get a perfect result:
    I mirrored the whole character A within the hair, merged a copy of the character (B), parented the mirrored hair to B and deleted A.
    smiley
    Post edited by Wolpi on
