Cannot find Victoria 4.2 in my daz library
Hi, I have installed and reinstalled my v4 with all the morhs again and again but it just does not show up in my content library on my daz studio 4.24. The name shows up but there's nothing inside.
I can import her from my poser 11 but I can't load any morphs onto her.
Any ideas?
  • felisfelis Posts: 6,502
    What do you mean with "The name shows up but there's nothing inside"? Do you get an error?
    And where are you looking?
  • Sorry I have found all her morphs but when I inject them nothing happens. I can't change her figure or face. I usually go into shaping with g8 but nothing comes up for v4
  • LeanaLeana Posts: 13,501
    edited August 2025
    V4 INJ morphs for the standard head and body shapes don't apply the morph, they only enable the morph dials.
    Look for the morph dials in the Parameters tab, not shaping. Shaping tab is only for DS-format figures.
    Post edited by Leana on
    I only have Victoria 4.2 so only 2 morphs to change to a male body, and they works.
    Which morphs do you have?
  • crosswindcrosswind Posts: 10,249
    Have you loaded the Base morphs and morphs++ of Victoria 4.2. cr2 with PowerLoader dialogue ? (ss1)
    If you have, you should be able to find the morphs in Shaping pane.  Then you dial them there.  (ss2)
    2560 x 1392 - 370K
    2560 x 1392 - 546K
  • If the morphs aren't showing up in Powerloader, Parameters tab, or the Shaping tab when you run the INJ file, it's prossibly because the DzCreateExPFiles.exe didn't run or glitched, or files are not in their proper paths for the exe to add the channels.
    The path to this file is Runtime\Libraries\!DAZ.
    Try running this manually, and it should create the channels for the morphs in V4.
    When you load the V4 figure after this, the morphs should be there, and you can verify it by running the INJ, or by enabling Show Hidden in the parameters or shaping tabs.
    The channels should appear in their appropriate paths as EMPTY-(Morph name) and be greyed out if the exe ran properly and the morph files were in the correct path.
    If they're still not showing up, make sure the morphs you're adding are in the correct path, which is the same as the script, but one level down in the Victoria 4 directory.
    Runtime\Libraries\!DAZ\Victoria 4.
    If they're not there, there may be a problem with your install path, or the file itself.
    Check DIM or what ever install method you're using to make sure the path is correct.
  • BejaymacBejaymac Posts: 2,002
    edited August 2025
    The attached image is what you should see if you have her installed correctly, only those under "Morphs|Shapes" will show in the Shaping tab when you have her Body selected, head morphs only show if you have her head selected which is also how it works in the Parameters tab.
    1366 x 768 - 125K
    Post edited by Bejaymac on
