Errors with the new updates
This month I've had problems rendering models with a subdivision level above 3,when I render, it keeps loading but never starts rendering. I've never had these problems before, and now when I try to use Dforce, an error appears, something about my 4090. It still works, but I can no longer see how the object is simulated.
I've updated my drivers, but it's still the same. My specs:
RTX 4090
AMD Ryzen 7 5700x 8-Core
64 GB RAM
Windows 11 Pro
  • felisfelis Posts: 6,534
    Is your GPU listed in Render Settings > Hardware?
    And is it listed in Simulations Sedttings > Advanced?
    Yes, on both lists.
    When you have had such a case, try to attach your log. It might tell more.
    Log can be found in Help > Troubleshooting > View Log
    2025-08-16 14:40:44.880 [WARNING] :: \src\sdksource\fileoutput\dzassetoutfile.cpp(11541): No geometries match the vertex count of morph "PHMEyelashesCurl"
    That's the only “warning” it gives me, and then it just keeps loading forever.
    I think it's an old model, but I don't remember.
  • Posting the whole log might be illuminating.
  • I figured it out. Apparently, I have to set the subdivision level and the render subdivision level to the same number. Every time I used 3, the render subdivision level was set to 4, so now I've set both to 3 and it works
