[Released] Gobo Quadlight Kit [Commercial]
The Gobo Quadlight Kit is a self-contained projection cone that folds an entire lighting bay into a single prop: a circular quad of four colour-selectable emitters sits at the narrow end, two concentric ring strips float farther down the funnel, and a front disc accepts opacity maps so the same fixture can fire a clean wash or create gobo-like patterns across your scenes.
Fifteen prebuilt looks arrive as drag-and-drop subsets, each one already wired with its own colour mix, power level, and pattern rotation. Use included pose presets to spin the gobo in 15-degree clicks, mute or tint any of the six lights, or swap to one of included color swatches, luminance presets, and light temperature options.
Because the quad and rings inhabit a single lightweight node the kit is easy on scene hierarchy, simple to animate, and perfect for portraits, fashion, VFX or stylised key art—drop it in front of your subject, tilt the cone, let the overlapping light beams paint your model with graphic colour and shadow, and you’re ready to render. Whether you want soft gradient washes, graphic fashion backdrops, or complex sci-fi rim lighting, the Gobo Quadlight Kit delivers studio-grade control in a single, smart prop. Dial the colours, spin the pattern or lights individually, and watch your render explode with depth and attitude.
