Install ruined my ability to use Studio
I was on an old Alpha that worked with my 5080ti card and all was well. But every time I loaded I got a nag screen .... new version ... update it ... youll love it...
I finally did.  And now nothing works.  I can install to my C drive fine, the binaries go right in.  I have my content on a network attached drive and this is suddenly useless.  First when I go through the tree in the content pane (the one time it loaded at all) i could see the directories but only some of them would show content.  Most of the time though it shows nothing at all when I click on that entire library.  Also I cannot install any content, when I try it says this example from the DIM log:
2025-08-02 11:50:59.802 [INFO] :: Installing: 92841-1 : Snow Queen LIE Makeup Collection for Genesis 9
2025-08-02 11:50:59.817 [WARNING] :: Open Settings File Failed - No error occurred: /[My Path]/InstallManagerFileRegister.json
2025-08-02 11:50:59.817 [WARNING] :: Could not set permissions:  /[My Path]/InstallManagerFileRegister.json
2025-08-02 11:50:59.817 [WARNING] :: Open Settings File Failed - The file could not be opened:  /[My Path]/InstallManagerFileRegister.json
The files are all there, they do open and are populated.  But Daz will not access them.  If I explicitly try to run as Admin DIM says it cannot run with elevated priveledges (probably a good thing).  But my personal account has full access to this path.  By the way This also affected my Alpha build so basically nothing works.
Any ideas?
  • Is the Network Attached drive mapped to a drive letter or is it using a UNC path? The latter should never have worked.
