Rig bones show all the time
Whenever I bring in a rigged FBX figure the bones always show - as if I was using the joint Editor tool, e.g. I can have the Node selection tool or the Translate tool selected, and still they appear. At least they don't show when I render.
Is there some setting that I can turn off so they don't appear? The only way I can currently make them go away is to go to the Scene tab and hide each bone. Doable but a pain, since there are so many bones.
  • LD1LD1 Posts: 178
    I forgot to include a pict to show you what I mean. BTW: I took the screenshot with the Viewport set to Texture shaded since you see the bones better than in the Iray view.
    672 x 831 - 236K
  • crosswindcrosswind Posts: 10,253
    You select the figure in Scene pane, in Parameters pane, filter by Show Bones, then turn it off.
  • LD1LD1 Posts: 178
    Thanks Crosswind. I could have sworn that I tried that yesterday and it didn't work. But it works now! Thanks again.
    No problem !
