Iray render server RTX 5090
Has anyone managed to get the 5090 functioning with the iray render server? I've updated everything, but I'm still having the error: There is no CUDA-capable GPU available to the iray photoreal renderer.
  • LeanaLeana Posts: 13,626
    Which version of Iray server are you using?
  • JeremionJeremion Posts: 54
    edited July 2025
    It is a message which appears when you start an iray server (you need a 2024.1.x to get the 5090 working). If you start a rendering from Daz 2025 Alpha from the bridge to iray server, it will work as expected with the GPU. However, you can't use daz 4.24 with its bridge to get the 5090 working through bridge... not the right version. You must use daz 2025..... (which is rightnow a nightmare for me, viewport mouse always visible, moving in the viewport doesn't work properly, etc.).... Yey.
    Post edited by Jeremion on
