How to automatically dial a clothing body morph when it's not named as intended ?
ElorElor Posts: 4,102
Hello,
According to the store description, 'dForce Hot Caribbean Nights for Genesis 9' has Victoria 9 among the supported shapes:
https://www.daz3d.com/dforce-hot-caribbean-nights-for-genesis-9
But when I'm loading it on Victoria 9, the body morph used is an auto-generated one (as shown by me being the author and the absence of the file path field):
Studying the situation a bit further, there is indeed a 'Victoria 9 Body' morph, but the file is name 'Victoria 9 Body.dsf':
http://docs.daz3d.com/doku.php/public/read_me/index/110736/file_list
On the clothes themselves, it's appear as a visible morph and when dialing 'Victoria9_body_bs_Body' (which is what Daz Studio is looking for if I'm understand how things work) down to zero and Victoria 9 Body up to 100%, everything seems to fit perfectly:
Is there a solution to solve the problem (outside of having to fill a ticket, which I'm planning to do later) and to get the morph created by Sveva to be used automatically by Daz Studio when fitting these clothing items on Victoria 9?
590 x 607 - 64K
409 x 684 - 47K
Post edited by Elor on
  • crosswindcrosswind Posts: 10,251
    edited July 2025
    Yeah, I could reproduce the issue. I wonder if the vendor wanted the user to manually dial the morph... but that seems to be wrong.
    It's easy to fix as below:
    - Locate the Victoria 9 Body.dsf, rename it to Victoria9_body_bs_Body.dsf.
    - Open it with Notepad++. Ctrl + A. Go to menu: Plugins > MIME Tools > URL Decode...
    - Ctrl + H to Replace All: Victoria 9 Body with Victoria9_body_bs_Body.  Ctrl + S to Save.
    Then reload the skirt on G9, it'll work.
    1495 x 837 - 84K
    Post edited by crosswind on
  • Richard HaseltineRichard Haseltine Posts: 111,382
    Please open a Techncial Support ticket to report this as a possible bug. I am surprised those spaces are not replaced  with %20 etc.
    Better decode firstly... then they don't have to be encoded in DSON xxx files.
  • ElorElor Posts: 4,102
    edited July 2025
    Thank you, I fixed a copy of all the impacted files (including ones from another product by Sveva), renaming them correctly and placing them inside a library dedicated to temporary fixes. I'll open a ticket as soon as possible.
    A last question: do I open one ticket per product or one ticket for the two of them ?
    It is strange, especially because doing so without removing the autogenerated morph means the clothes will shrink inside a figure's body.
    Ah, I think one ticket will do. I did that once or twice, IIRC...
    And yeah, that was why I said it's wrong ~~
    edited September 2025
    While writing the ticket I submitted a couple of minutes ago, I saw that Base Feminine also has a morph created by Sveva and it was also not named in a way allowing Daz Studio to automatically load it. I'll fix it on my end too, because it can be a good starting point when creating full body morphs for characters based on Base Feminine.
    yes
