This is DAZ3D
SasquatchIsCoolSasquatchIsCool Posts: 262
edited July 2025 in The Commons
This is when DAZ3d meets AI.  Been practicing a lot with creating a system to connect the power of both.  I think I found it.   Anyone want training on this?  In fact can you find the items I used from DAZ3d?
Post edited by SasquatchIsCool on
  • shootybearshootybear Posts: 148
    I'm interested. :)
  • nonesuch00nonesuch00 Posts: 18,890
    I think a set of DAZ 3D renders, ComfyUI, Flux, Flux Kontext, controlnets, with some of those workflows at CivitAI can work really well together.
  • FSMCDesignsFSMCDesigns Posts: 12,858
    edited July 2025
    Nice. Too bad the hair waas screwed up around her ears. What animation app with you use. I have been animating DS renders with WAN 2.1 and framepack, sooooooo much faster than using keyframes and DS.
    Just did this in a couple of minutes with a DS render using WAN 2.1
    Post edited by FSMCDesigns on
  • SnowSultanSnowSultan Posts: 3,845
    FSMC, are you using a local Comfy install to run WAN 2.1? I'm curious to know if you can run a 3D animation through an animation AI model with a Lora and make it 2D, but almost every Lora I see for animation is p0rn.
    I'm interested as well.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,798
    edited July 2025
    the OP always starts new threads not revealing much
    you can use Wan2.1 to do this
    I use Pinokio but since you are a coder, conda and the GitHub repository would likely be more your thing
    https://github.com/Wan-Video/Wan2.1
    I don't want to hijack threads or share non DAZ related stuff but this is an example of what one can do
    I used a LoRa trained on my Brother in Fooocus for the images and the Cakeify LoRa in Wan for this
    I am using NIM online since my GPU can't handle the local install very well. For non nudity and longer vids I use Krea since they offer WAN 2.1 also. I don't think either has the option for any LoRAs.
    This is simple to do now in Midjourney
    Thank you very much.
     Last time I checked, Midjourney will censor anything more risque than a woman in a t-shirt and shorts. 90% of AI videos wouldn't exisit if Midjourney was the only method to generate them.  ;)
    Thanks for the insight, Wendy! I'll check it out when I get home.
  • windli3356windli3356 Posts: 297
    I spent quiet a bit effort and money to experiement on it and didn't like it, for one, nearly all AI models I used will change the face of my character (not for better) and doing all kind unwanted thing, picture to video was fine, but too much censorship on 100% legal and none NSFW stuff.
    If you want to do like simple video and keep things consistent  I'd say go to Haliou off of wavespeed.  It allows a little more saucier stuff.
  • NetherFalconNetherFalcon Posts: 885
    edited August 2025
    Veo 3 can also do some amazing things.  A secondary option would be Hailou.
    https://hailuoai.video/share/ai-video/p31EywrDyJ4J?source-scene=shared&source-media=shared_link
    Here's a video from Hailuo, animated from one of my renders.  They're good if you aren't concerned about audio.  Quick generation and follow the prompts decently enough, especially for the price and usage of the tokens.
    Post edited by NetherFalcon on
