convert uniform from gen 8 to gen 9?
dondrawdondraw Posts: 170
how complex is conversion of clothing from gen 8 actor to gen 9?
my user guide has gone missing.
thanks,
dondraw
  • felisfelis Posts: 6,502
    edited July 2025
    If you try to fit it to G9 it will open an autofit dialouge, where it asks which character it was made for (G8), and then it will run. You can choose different templates, and the choise of template can change how the conversion is.
    If the original has custom bones they will not be there after transformation.
    Then how well it fits G9 can change. There might be some weightmap you want to edit, or there might be some mesh parts that needs a little correction. If small it might be done inside Daz Studio, but more likely in a modeller. Or you might just decide to live with it. It depends on your usage of that item.
    Post edited by felis on
  • dondrawdondraw Posts: 170
    thanks, frlis, good info. i don't know how to make the corrections you mention, but i can plunk around fnd find out. i'll go for the costume.
    dondraw
