The Last Hiro not working at all in Daz 4.9!
SyphonapteraSyphonaptera Posts: 192
edited March 2016 in New Users
Dearest,
does anybody own and use 'The Last Hiro'  (  http://www.daz3d.com/the-last-hiro ; ,      SKU:3265 )  in Daz 4.9?  It does not do anyhting on my side when I use it with Hiro 3.
The Hiro 3 face and body don't  morph at all when I click on The Last Hiro injections /  morphs . The beard variations do actually show up on the Hiro 3 Figure./....but that is all...  :(
Anyone with the same issue ?
kind regards
Peter
Post edited by Syphonaptera on
  • barbultbarbult Posts: 27,595
    Here is a corrected link to the product. I'm sorry, I don't own that particular product so I can't test it for you.
  • kaotkblisskaotkbliss Posts: 2,918
    Are there moph dials in the parameters tab? select the character, go to parameters, then under 'model name'->Actor are different types of morphs like Full body, Real world, Head, upper, etc. Check those and see if your Last Hiro morph is in there. If it is, dial it up.
    I can't remember exactly but I want to think that some injections didn't actually apply the morph, just "install" the morph dial for the character.
  • evilded777evilded777 Posts: 2,549
    edited March 2016
    If you installed Hiro 3 and his moprhs and or this product via Connect, its not likely to work properly.
    Figures previous to Genesis need to be installed manually or via DIM to get morphs and things to properly function (Hiro 3 being pre-Genesis).  I think this is most likely the issue you are experiencing. So.. to be safe, uninstall everything Generation 3 related (head and body morphs, base figures, character sets) and reinstall them via DIM or manually.  That should correct your issues.
    Post edited by evilded777 on
  • Are there moph dials in the parameters tab? select the character, go to parameters, then under 'model name'->Actor are different types of morphs like Full body, Real world, Head, upper, etc. Check those and see if your Last Hiro morph is in there. If it is, dial it up.
      But, I asked for a refund , I am not wrestling with products , they should be working 100% ,  :)
    Thanks for the
     To my knoiwledge I did not find any "The Last Hiro"  morphs when selecting Hiro 3 (parts) in the Par-tab...  :(  But anyway, thanks for the help but I already got store credit for it. Maybe I'll ask tech-support if I can buy Last Hiro again and try some more .....
    cheers
    Syphon Pete
  • If you installed Hiro 3 and his moprhs and or this product via Connect, its not likely to work properly.
    Hiro 3 and Last Hiro were installed via DIM.......Once inside Daz 4.9 they had (like all DIM articles now seem to have in Daz 4.9 after installing )  still this annoying (install) white arrow in the right upper corner of the products thumbnail. I also 'installed' them and they showed up as 'new' in Daz 4.9 but it did not work .
    Do you think their should no more be the  (install) white arrow in the right upper corner of the products thumbnail? Other products in my Daz 4.9 do work fine , also with this (install) white arrow in the right upper corner of the products thumbnail.
    Thnks , NP  yes
    The little white arrow means it is available to install with Daz Connect. If you have already installed with the DiM, you don't have to install again with Daz Connect. Doing so will install it again in another place on your hard disk and waste space. You can ignore the white arrow if you prefer to install with DIM.
    Yeah, you don't want to install both. That might have contributed to the problem.
    It is an old figure, with all old figures get out of Smart Content and look for it in Content Library pane under Poser Formats.
  • fixmypcmikefixmypcmike Posts: 19,729
    It seems to be working fine for me -- in fact, I installed Hiro 3 using Connect and The Last Hiro using DIM, and the morphs all work fine.
  • SyphonapteraSyphonaptera Posts: 192
    edited March 2016
    Thank you for your reply .
    Indeed, I installed all again and now the arrows are gone....but my diskspace is also gone....This feature in Daz is so confusing, why doesn't  Daz just ignore the arrows when you minstall all via DIM?
    Anyway, first I am trying to get rid of those double installments and then I'll try 'The Last Hiro'again.
    Thanks all of you. Cheers
