Inner Glow
Is there a morph that gives the appearance that a character is glowing internally? I'd prefer it to be G8 based but I'll take any version.
  • felisfelis Posts: 6,626
    Not sure how a morph should look like an inner glow. I would more expext some surface settings or a dedecated setup.
    What do you imagine inner glow should look like?
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,790
    like the mouths in the old Poser FireFly renders?
  • richardandtracyrichardandtracy Posts: 8,238
    You can set an emissivity value for the skin. Under the surfaces tab, click on the character's 'Skin', make the emission colour white and then start playing with the values of the candella/lumens per square metre. It may be worth experimenting with putting the diffuse texture in the emission colour channel too. Then try eyes and mouth etc. You know what you want, and haven't stated what you want in too much detail, so I can only give general pointers. I use a small negative skin emissivity on my favourite character to emphasize AO which seems to have a slight beneficial effect except in dark environments when it goes horribly wrong. Regards, Richard.
    edited July 2025
    With a primitive.
    2240 x 1400 - 4M
    Post edited by felis on
  • crosswindcrosswind Posts: 10,351
    And Emission slot supports placing maps, so you also can add a mask map to make various subtle change, e.g. faded glowing or partial falloff ~
