Upper & Lower
Drogo Nazhur
There is a tool for G3 & G8 that allows you to split morphs across upper and lower body. For example, it takes the body builder more and gives me an upper and lower body builder slider. Is there a tool like this that will work for G2?
If you mean the morph splitter dForm then you can make your own, using a weight mapped dForm (the dForm doesn't do anything itself, it just provides a carrier for the weight map).
It's not for Genesis 2 but it should give you an idea how it's done once you have the dFormer ready (I don't know if you can use the one from Genesis 8 or 9 on Genesis 2):
No, weight-maps don't translate between geometries (map here doesn't mean an image but a correspondence between two lists, of vertices in the model and of weights - in this sense a morph is also a map, between vertices and position offets, as are other things).
thank you
