Genesis 9 eye blink problem [closed]
AxessAxess Posts: 9
Hi everyone,
I'm having an issue with my Genesis 9 figures: the eyes are now blinking asymmetrically (see attached images).
Initially, I had the "The Age for Genesis 9" asset installed, and with that, the issue was even worse — both eyes were affected. I've since uninstalled the asset, which improved things somewhat, but the problem persists: the left eye closes correctly, but the right one still doesn't.
I found some forum posts mentioning that "The Age" causes problems, and I cleaned up everything related to it as best I could. However, I'm still stuck — one eye behaves normally, while the other clearly has a bug.
There are no hidden morphs active anymore, and I haven't noticed any unusual sliders that could be causing this.
The issue occurs with all Genesis 9 figures I've tested so far.
Has anyone else experienced this and found a fix? Any ideas would be appreciated.
1066 x 787 - 466K
1241 x 505 - 499K
1534 x 538 - 444K
Post edited by Axess on
  • AxessAxess Posts: 9
    Well... embarrassing, but I found the culprit.
    As so often happens, you find the solution right after posting for help.
    Problem is resolved on my end.
    Thread can be closed or deleted – whatever the mods prefer.
    Thanks anyway!
  • jmucchiellojmucchiello Posts: 2,587
    And the solution is?? I've had this problem sometimes as well.
    An eye morph from another model somehow snuck in.
    When I enabled hidden properties and searched for 'eyes' under Genesis 9, it showed up – highlighted in blue. Setting it to 0 fixed the eyes. I think the color depends on the morph from the model that got mixed in.
    The other major issue was the asset 'The Age', which I uninstalled. But same story there: hidden properties had active morphs that shouldn’t have been enabled at all.
  • memcneil70memcneil70 Posts: 6,178
    A new update to The Age for Genesis 9 dropped into DIM today and a confirmation received it works.
