Aeon soul - Zero One - Morphing Item
Can the asset "Aeon Soul - Zero One" be morphed
if it is, how?
I am asking because normal method did not work
so, help please
  • felisfelis Posts: 6,630
    It is a mesh, and therefor it can be morphed.
    What have you tried and what was the result?
  • stevejintastevejinta Posts: 27
    What have you tried and what was the result?Hello FeI did the same morphing method
    Hello Feris,
    I did the same old morphing method
    but instead of successfully, I got "grometry did not match"
    Yes, I changed it to base
    Yes, the face is equal
    so I am not sure what I am missing
    I tried with the pants.
    And yes, I found that there are some loose verteces that gets removed when importing to blender.
    I don't know if another method of transferring could keep these verteces.
  • crosswindcrosswind Posts: 10,356
    You have to make sure the vertices are equal... not only the face. Which product did you manipulate... to be exactly ?
    Some vendors leave unused vertices on the item... If you checked the option of "Remove Unused Vertices" when exporting to OBJ, you would be not able to import the OBJ as a morph with MLP.
    Check if that was the case you had ~~
    I have seen that too, what is the other method? I would like to know more
    by the way, thank you for mention, Felis
    Hello Crosswind,
    the product is "Expressive Chroma Poses and Zero One Clothes for Genesis 8, 8.1, and 9"
    I have done it checked and unchecked on "Remove Unused Vetices"
    but it still "did not match"...
    thank you Crosswind for mention it
    Hmm~~~ Well, what application did you you for shaping the clothes... Blender ?
    If you use Blender, Blender automatically removes the unused vertices. You have no way to change any settings to avoid this behavior. Then, after you export the clothes to OBJ, and import into DS, vertex count will mismatch.
    There're two solutions ~~ :
    - Export clothe from DS to Blender by using Diffeomorphic Daz Importer. This add-on doesn't remove unused vertices.
    - Before exporting clothes to OBJ in DS, switch to Geometry Editor tool, Polygon Selection mode. Then, Geometry Editing > Delete Unused Vertices. (ss1)
    2023 x 1374 - 610K
    Hey Crosswind,
    you read my mind, thank you
    NP !
