Genesis 8 model loads with a dent
When loading my Genesis 8 female, the model loads up with a small dent on the right pec area. I've ununinstalled the base model and reinstalled it and still nothing. I'm going over the log as we speak, and nothing jumps out. Any ideas?
  • felisfelis Posts: 6,497
    Try in Parameters to enable 'Show hidden' and click 'currently used' and see if anything come up.
  • Richard HaseltineRichard Haseltine Posts: 111,306
    Please put the viewport in a non-textured mode,or use the Dev Build version of the figure, for your screen shot.
    That's the first thing I did.
    Sadly, Richard, it shows up in the dev version as well.
    2955 x 2023 - 1M
  • crosswindcrosswind Posts: 10,241
    Try Restore Figure (Ctrl + Shift + F), see if there's any change.
    I was expecting the issue to show, it was just another way of having an untextured screenshot. felis is almost certainly on the right track
    I wish it were that simple.
    It should be that simple. All shape / pose control properties (incl. hidden ones) under Currently Used of a G8.XF Dev Load should be Zero. But your screenshot doensn't seem to be like that. There're quite a few non-zero properties dialed there ~~
    2014 x 1289 - 432K
  • MidnightProphetsMidnightProphets Posts: 68
    edited July 2025
    I didn't know that would be an issue. It's been that way for god knows how long with zero problems.
    Post edited by MidnightProphets on
    Try zero rather than restore - the problem may well be a non-zero default value, and estoe just resets things to their defaults.
     Update:
    Okay so I loaded the Gen 8 in dev mode. Went to Edit>Figure>Zero>Zero Figure
    And the problem went away. But when I loaded a new model the problem resurfaced. Perhaps I could upload a scene or subset with just the Gen 8 model for anyone that have ideas?
    edited July 2025
    In your case, why I suggested you Restore first is that you can precisely identify the culprit and then save modified assets... (first Restore then Zero, you can compare the property list to quickly locate the problematic property...) otherwise your issue won't be gone next time you load G8F Base or Dev Load ~~  Uploading your scene or subset won't help 'cause the culprit is within your data folder, not ours...
    Now, if check the property list, can you find out the true culprit ? Then  you go to: File > Save As > Support Asset > Save Modified Asset..., can you locate any modified assets ? Post a screenshot of the list if you can ~~
    795 x 818 - 41K
    Post edited by crosswind on
     Turns out that Xtransfer was the culprit. Prior til this year I've never used this script even though it's been out for years. I was 1-5 at converting, but gave up because it kept crashing Daz. Anyway, the model whom I thought was successful, "Navel" morph was what caused this. Once I deleted the morph, everything loaded up perfectly. This has been an exhausting 3 days, but thank you to everyone here who helped.
    Removed your two new screenshots, please follow the above suggestons - untextued drawstyle or use the untextured  Dev Build fgure for your screenshots.
