How to download purchased items and install is not working
I attempted to download my purchases products but I get an error in Daz that all the files are not there. What is the easiest way to download these items and how do I get the installer to work? Also, when downloading in installer, I get a "retry" over and over.
  • felisfelis Posts: 6,502
    When it says 'retry' it is usually the servers that has an issue.
    You should be able to download your preferred way.
    I have just downloaded some with DIM, so I would suggest to just try again.
  • Thanks, I've no idea what I'm doing. Nothing is in Daz. It shows my figures, then they disappear. I clicked Smart Products and all products but they are gone. If I close out and open they come back.
    Try to post some screenshots of what you are seeing.
    How have you been installing?
  • barbultbarbult Posts: 27,499
    That sounds like you may have Microsoft OneDrive installed and it is moving your files to the Microsoft cloud. There are many forum threads that discuss this issue.
  • I have unlinked OD but it still shows in the default directory! How do I change this? One Drive is a nightmare. I've searched here but no answers. Thanks
    For changing the content library path, you must edit it in Daz Studio Edit > Preferences > Content > Content Directory Manager and then under the relevant types.
    And if you are using DIM to install, you must also change it there under Advanced Settings > Installation.
  • I'm done with this. Now I cannot uninstall Daz! It is not in the Remove programs and I uninstalled DIM
  • Richard HaseltineRichard Haseltine Posts: 111,363
    The Windows unisntall lst does not list things isntalled through other tools, such as DIM - reinstall DIM, uninstall DS (assuming you didn't delete the manifest fles it uses to track its work), uninstall DIM.
