Prayva Iray issue
Puma283fPuma283f Posts: 52
edited July 2025 in New Users
so i recentlly purchased Prayva on a good deal and i noticed something really odd, When i tested the Nvdia Iray with the Tattos on her Arms the arms are discolored yet the tattos work fine on her torso and legs is there a workaround to this please help
1152 x 802 - 1M
Post edited by Puma283f on
  • felisfelis Posts: 6,614
    Link to product https://www.daz3d.com/tmhl-prayva-for-genesis-81-female
    I don't have her.
    You havent done anything else than loading the tattoo?
    It could be a gamma issue. If you in the Surface tab, finds the arms surface, and for Base Color and Translucency color left click and choose Image Editor. Then check that gamma is 0 for both.
  • Puma283fPuma283f Posts: 52
    I don't believe it, Setting the Gamma to 0 on the base color actually worked
    Good you got it solved.
    If you can repeat it, i.e. load the character and then the tattoo, and it still look wrong, I will suggest you raise a ticket to Daz. They will then verify and contact the PA, that there is an issue in their product.
    Go to this page https://bugs.daz3d.com/hc/en-us
    and sign in. Then you can raise a technical ticket, with a description of the problem.
