Need to Know before I purchase.
Is Leyton Hair available for purchase as a Daz Original without it also being a new release?  I have a coupon that says to take an amount off Daz Originals, but with the added caveat that it shouldn't be a new release.  There's no marking I can find for something being a new release - I think. Thanks.
    Leyton Hair is not a new release, so you should be fine.  New releases (items released within the past 60 days) have a green flash in the upper right corner saying "New".
  • TaozTaoz Posts: 10,340
    The monthly $6 PC coupon works with new releases though, so if you're a PC member don't forget to use it (many do).
  • JMCarriganJMCarrigan Posts: 179
    Thanks! very much.
  • chris-2599934chris-2599934 Posts: 1,972
    For future reference, you can safely try out coupons to see if they work.
    Just put the stuff you want to buy in your cart, go to your shopping cart page, and type the coupon code in the box in the top left. If the coupon doesn't apply, it'll tell you. If it does apply, the discount will be applied to the iems in your cart - but nothing actually happens until you check out. If you change your mind and empty the cart or cancel the coupon, it's still available to use on another purchase. Only when you actually buy something doe the coupon get used up.
