Annoying spot render problem
fred9803fred9803 Posts: 1,565
When I go to the spot render tools and render to New Window the resultant image is supposed to be exactly in the same position as if I rendered the whole scene, and I should be able to cut and paste the image with it pasting onto the whole scene image where it should be. Although it's close it never exactly does and I have to reposition it to the correct place.
Is there a way of correcting this or do I have to just live with it? I always render to active viewpoint rather than a specific size and I'm thinking this may be the problem. Any suggestions would be appreciated. Cheers.
  • scorpioscorpio Posts: 8,534
    I use spot renders all the time and don't have the problem you're getting, you might check that you are rendering through the same camera that the main image is rendered through.
