Lighting Collection Prop Set, do these emit light?
MistaraMistara Posts: 38,675
are these light props set up as light sources?
or they need lights manually added?
thanksenlightened
  • MedzinMedzin Posts: 337
    They work fine as standalone lights in Iray.  I did not try them with 3Delight
  • BastrupBastrup Posts: 42
    If it's this one http://www.daz3d.com/lighting-collection-prop-set  the answer is yes, they're ready to go
    thanks!
    so if i put these lights in a room with Eva7, my render is reasy to press the render button?
  • PetercatPetercat Posts: 2,324
    You might have to adjust the light output.
    Yes, as long as you remember the default Iray lighting setup includes an environment light that you'll need to turn off, and the Tone Mapping default values are set for that environment, which is a bright sunny day outdoors. For indoor lighting, you must adjust the Tone Mapping settings as if you were fiddling with the manual controls on a camera.
