Hair doesn't follow when posed
I ran into a problem with newly acquired hair https://www.daz3d.com/dforce-strand-based-fe-chic-layered-short-hair-for-genesis-9 . It seems to fit OK when the figure is in a base pose but does not follow the head when the figure is posed. I first noticed the problem when loading the hair on a posed G9 figure with some morphs. If I put the figure in the base G9 pose, the hair loaded but then stayed there if I posed the figure. In case there was anything weird about the custom character, I repeated the test with a stock G9 figure and had the same happen.
I don't recall running into this problem, at least not with a hair being used on the figure for which it's intended. Ideas, anyone? I have many hair items from this vendor and have never run into this problem - I love their strand hairs and have a lot of them.
  • Richard HaseltineRichard Haseltine Posts: 111,348
    Have you runb a simulation?
  • GhostofMacbethGhostofMacbeth Posts: 1,774
    I am going to guess you might not have had G9 selected when you applied the hair. Try again, making sure the figure is selected when you add the hair. I have done that too many times.
