Morphing flower - from closed bud to open?
Hey folks.
Has anyone seen a rose that morphs, from closed bud shape to open?
I have found an orchid version but really was looking for a rose one.
Would also consider any other flower type that morphs from closed to open.
Thx, Domwink
  • MasterstrokeMasterstroke Posts: 2,522
    I doubt this would look great at middle morph target values.
    Rigged pedals would most likely work better.
  • tsroemitsroemi Posts: 3,668
    edited July 2025
    Really good question, I'd sure like an opening flower als well! OP, where did you find the orchid?
    @Masterstroke is probably right, rigged petals will likely look better than just a morph. But ssome morphing will be needed nevertheless I guess, so rather a combination. Sounds complicated, that's probably why one cannot find any around ...
    Post edited by tsroemi on
  • Found the Orchid here, it's good.
    https://www.daz3d.com/morphing-orchid
    Thank you, I had never noticed that before! Hope somebody else will still chime in to answer your original question.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,812
    edited July 2025
    another possibility now DAZ studio has animated visibility in render is to have several flowers in stages of opening and keyframe the visibility of each
    one then could use an interpolation software like RIFE to tween it smoothly
    I use the Flowframes implementation https://nmkd.itch.io/flowframes
