Can it split a single model into two separate models?
brckbrdbrckbrd Posts: 15
edited July 2025 in Daz AI Studio
Like if you have a model of a pair of gloves how would you go about about splitting that model into two separate models, one for the left glove and another one for the right glove? Is this something the AI can handle?
Post edited by brckbrd on
  • Richard HaseltineRichard Haseltine Posts: 111,984
    Daz AI Studio is no longer running, but when it was it was an image generator not a 3D tool.
  • felisfelis Posts: 6,630
    Inside Daz Studio you can hide one glove with the geometry editor.
    If you want 2 seperate gloves it would be easiest to export to a modeller and there split it into two.
  • Roman_K2Roman_K2 Posts: 1,277
    Did you want the glove, or the hand? Gloves and hands are often things that need to bend, and so they are "rigged" or have morphing attributes or tools attached. Messing with the geometry will usually lead to your losing this functionality, at least temporarily.
    If you wanted one glove (of a pair) to disappear you could de-select it in your DAZ Studio "Scene" frame, or you could temporarily hide the geometry with the Geometry Editor.
    For what it's worth like a good newbie I asked Google's A.I. service if it could create .OBJ files. The answer was no. Then again it's early days and some of the documentation - and even the on screen controls and buttons - is a bit thin at the moment.
