Daz3d 4.24 crashes when loading a scene
Hello everyone, lately it's been crashing very frequently (blue screen) with the error IRQL NOT LESS OR EQUAL in nvlddmkm.sys, which indicates some Nvidia-related issues. However, it renders fine, games run normally, and stress tests pass without problems. But when loading a scene, it crashes to a blue screen consistently about 1 out of every 4-6 attempts!
I completely removed the drivers using DDU in Safe Mode, but it didn't help. Using latest WHQL drivers 576.80
GPU is not overheating, i'am using custom loop and max temps is 50c (hot spot) on GPU and 65 on memory
Post edited by nimonsi_5039111 on
  • LeanaLeana Posts: 13,499
    Is it with a specific scene, or randomly with any scene?
     It's completely random.
  • Right now, I’ve found a janky workaround: I open Daz3D, set up a scene, save it, exit completely, then reopen… and so far, no crashes… for now.
    Another thing: I use the Render Queue script—I dump all my daily renders into it and let it process overnight. Surprisingly, it runs flawlessly all night, even though it’s technically opening and rendering scenes one by one.
  • ImagoImago Posts: 5,782
    I reported an issue like this a couple of times. Same workaround as your case, even if the issue is caused by TBB.DLL and DAZCore.DLL files.
    All works fine in 4.21, try that again.
