Trying to run a custom script for batch rendering, without sucess so far.
I'm trying to create a batch render script to speed up my workflow, but I have very little experience with Java, much less using it with Daz3D.
Can some spot anything wrong with the script I came up with?
// CustomRenderQueue.dsa
// Batch Render UI for Daz Studio
var win = new DzDialog;
win.caption = "Batch Render Queue";
// Queue and variables
var sceneQueue = [];
var currentSceneIndex = 0;
var renderSettingsPath = "";
var renderMode = "Still"; // or "Animation"
var settleTime = 5;
var killTime = 60;
// === UI Layout ===
var layout = new DzVBoxLayout(win);
// SCENE QUEUE LIST
var queueLabel = new DzLabel(win);
queueLabel.text = "Scene Queue:";
layout.addWidget(queueLabel);
var queueList = new DzListBox(win);
queueList.minimumHeight = 100;
layout.addWidget(queueList);
var addSceneBtn = new DzPushButton(win);
addSceneBtn.text = "Add Scene (.duf)";
layout.addWidget(addSceneBtn);
// RENDER SETTINGS PATH
var settingsLabel = new DzLabel(win);
settingsLabel.text = "Render Settings File:";
layout.addWidget(settingsLabel);
var settingsPathBox = new DzLineEdit(win);
settingsPathBox.readOnly = true;
layout.addWidget(settingsPathBox);
var selectSettingsBtn = new DzPushButton(win);
selectSettingsBtn.text = "Choose Render Settings...";
layout.addWidget(selectSettingsBtn);
// RENDER MODE
var modeLabel = new DzLabel(win);
modeLabel.text = "Render Mode:";
layout.addWidget(modeLabel);
var modeDropdown = new DzComboBox(win);
modeDropdown.addItem("Still");
modeDropdown.addItem("Timeline");
layout.addWidget(modeDropdown);
// SLIDERS
function addSlider(labelText, min, max, value) {
var container = new DzHBoxLayout();
var label = new DzLabel(win);
label.text = labelText;
container.addWidget(label);
var slider = new DzSlider(win);
slider.minimum = min;
slider.maximum = max;
slider.value = value;
container.addWidget(slider);
layout.addLayout(container);
return slider;
var settleSlider = addSlider("Settle Time (s):", 0, 60, 5);
var killSlider = addSlider("Kill Timeout (s):", 10, 300, 60);
// START BUTTON
var startBtn = new DzPushButton(win);
startBtn.text = "Start Rendering";
layout.addWidget(startBtn);
// === BUTTON CALLBACKS ===
addSceneBtn.clicked.connect(function () {
var file = FileDialog.doFileDialog("Choose Scene File", "", "*.duf");
if (file) {
sceneQueue.push(file);
queueList.addItem(file);
selectSettingsBtn.clicked.connect(function () {
var file = FileDialog.doFileDialog("Choose Render Settings", "", "*.duf");
if (file) {
renderSettingsPath = file;
settingsPathBox.text = file;
startBtn.clicked.connect(function () {
if (sceneQueue.length === 0) {
MessageBox.information("No scenes in queue.");
return;
renderMode = modeDropdown.currentText;
settleTime = settleSlider.value;
killTime = killSlider.value;
renderNextScene();
// === RENDERING LOGIC ===
function renderNextScene() {
if (currentSceneIndex >= sceneQueue.length) {
MessageBox.information("All scenes rendered!");
return;
var sceneFile = sceneQueue[currentSceneIndex];
App.loadScene(sceneFile);
if (renderSettingsPath !== "") {
App.applyRenderSettings(renderSettingsPath);
Timer.startTimer(settleTime * 1000, function () {
if (renderMode === "Timeline") {
App.renderTimeline();
} else {
App.render();
Timer.startTimer(killTime * 1000, function () {
callRestart();
function callRestart() {
var batFile = new DzProcess;
var batPath = App.getAbsolutePath("RestartDaz.bat");
if (batPath) {
batFile.start(batPath);
App.quit();
// === OPEN WINDOW ===
win.exec();
The only error I get when I run is this:
Executing Script...
\src\sdksource\general\dzscript.cpp(1192): Unhandled error while executing script.
Result:
Script executed in 0 secs 7 msecs.
Does anyone know what I am doing wrong?
  • CES3DCES3D Posts: 240
    You need to modify the code within the function addSlider.
    The DzHBoxLayout constructor requires a parent widget or layout as an argument.
    http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/object_index/hboxlayout_dz
    DzSlider is an abstract class and cannot be instantiated.
    Please instantiate its derived class, such as DzIntSlider (or DzFloatSlider).
    http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/object_index/slider_dz
    Insert print statements or terminate the script as needed to identify where the error occurs.
    // SLIDERS
        var container = new DzHBoxLayout(layout);   // argument added
        var slider = new DzIntSlider(win);          // DzSlider -> DzIntSlider
        // Since the Parent is specified in the DzHBoxLayout constructor, I think this line is unnecessary.
        // layout.addLayout(container);
        return slider;
    My suggested fixes ensure the dialog appears without errors, but I haven't verified if the subsequent behavior aligns with your intended functionality.
    // SLIDERS
        return slider;
    My friend, thanks for the help. Though I'm still far from perfecting the script, it fixed the issue.
    Also thanks for pointing out the documentation site, it was very instructive!
    // SLIDERS
        return slider;
    Thank you, you helped more than you imagine. I completely forget about the documentation, so thanks for the links too.
