Skin color
HI can someone tell me why my posers when rendering that the skin renders darker than my picture which setting is it that i would edit so it appears the same as posers
please and ty using 4.9 and set on delight attachinga pic showing where i did a small render test and skin is 3 times darker
Thank you
1366 x 768 - 503K
  • Richard HaseltineRichard Haseltine Posts: 111,430
    The preview is only a rough guide - if you want soemthing closer use the Aux Viewport in IPR mode for 3delight, or use the nVidia Iray preview mode in the main or Aux viewport for Iray. Which engine are you using?
    It's important to remember that renderers don't all react the same way to material settings; this is why many recent products have both 3Delight and Iray materials. And the Viewport that you see before rendering uses yet another renderer, OpenGL, which is directly dependent on the capabilities of your graphics card. You'll never have one set of materials that work the same way in all of them.
  • scorpioscorpio Posts: 8,533
    Ligthing also has an effect on how things look.
