New here, FBX Export stopped working
Hey!
Hope this is the right place. I tried doing a search for the topic but for some reason the forum kept timing out when searching for that topic.
Anyway, FBX export used to work just fine the first time I tried it. Then I tried a few settings and now it only exports the skeleton, the hair, the teeth and the eye lashes. I think the problem started after I installed the Blender Bridge, but I am not 100% sure. Blender Bridge works fine (but I am not necessarily wanting to export to Blender).
I tried uninstalling and re- installing Daz Studio but that did not help.
Any help is highly appreciated!
Thanks!
  • felisfelis Posts: 6,497
    So FBX is working, but not exporting what you want it to export.
    What is your export settings?
  • SkipjackSkipjack Posts: 0
    Thanks for the reply!
    Here are my settings:
    Well it looks like the screenshot did not make it :(
    Guess that's because I am new?
    Let's try posting the screenshot again. Otherwise, I guess I will have to list the settings in text...
    967 x 933 - 90K
    Just tried an FBX export, that works.
    Instead of exporting everything, have you as a test tried to export a figure.
    You could either export to blender via blenderbridge or Diffeomorphic, and then further export from there.
    I tried exporting just the figure and that did not work either :(
    Yeah, I can do the workaround through Blender but it does not work as well as going directly from Daz Studio did (before it broke). It is strange that it suddenly stopped working, when it was working before.
    I can't really imagine why it should have stopped working, but I only use FBX seldomly.
    I can't really either. I tried all sorts of things but it does not work. I tried re- installing Daz Studio but that did not help. Also tried deactivating and re- activating the FBX exporter without any improvements :(
    Is there a way to reset all settings to default? Maybe some config file that can be deleted?
    Not sure if that is of any use, but I was able to successfully export as FBX from the latest Daz Studio 2025 Alpha, using the default settings.
    You have ticked a lot more in your settings than I have -. but I couldn't see any of the 'ticks' looking like it could create issues.
    But if Alpha works, maybe try to copy the settings to 4.24. Else I can attach my settings.
    Yeah, it is weird. I am using the exact same settings in both and Alpha works, the other does not. But Alpha is OK anyway. I will just keep using that one.
