Pd Iray Shader Kit 1
Leo ChenLeo Chen Posts: 697
Can not locate this product after installation.
Where I can find it?
  • TottallouTottallou Posts: 555
    edited March 2016
    If you used DIM it is under Shader Presets - ParrotDolphin
    If using connect it seems to be in under shaders & typing pd in the search box brings them up for me (see attached screenshots)
    375 x 607 - 154K
    356 x 333 - 94K
    Post edited by Tottallou on
  • Leo ChenLeo Chen Posts: 697
    Thank you,Tottallou.
    But just can not find it.
    666 x 661 - 404K
    620 x 678 - 404K
    640 x 919 - 548K
    663 x 727 - 111K
    After re-installing the product,I have found the product.
    But it is still not shown on Smart Content.
    703 x 699 - 358K
    1077 x 959 - 423K
    670 x 760 - 116K
  • barbultbarbult Posts: 27,475
    edited March 2016
    Take a look in the Shaders category.
    800 x 1000 - 421K
    Post edited by barbult on
    Thank you, barbult.
    It is strange that there is no shader catalog under Smart Content.
    PS: I have bought a lot of shaders that I thought I can only acess them from "Suface pane".
    908 x 848 - 141K
    edited March 2016
    Shaders can only be applied to surfaces. You have to select one or more surface(s) in the Surfaces pane before applying a shader. What you are experiencing in that regard is actually correct and normal behavior!
    1176 x 1000 - 464K
    edited March 2016
    Thank you, barbult.
    After selecting the object to be modified, the "Shader" catalog are shown in the Smart Contents.
    BTW, is that real necessary that DS hide this catalog before select an object?
    Any reason?
    1920 x 1081 - 341K
    1920 x 1081 - 330K
    Post edited by Leo Chen on
    If you uncheck the box "Filter by Context" in the lower left corner of the Smart Content pane, you might see everything. Filter by Context means that it filters out (hides) anything that is not compatible with the currently selected object. If you don't have anything selected, there is nothing for a shader to be compatible with. That is my guess.
    Thank you,barbult.
