What are the minimum System Requirements for the current version of Daz Studio?
WahilWahil Posts: 308
edited June 2025 in Daz Studio Discussion
And where is it officially located?
The closest thing I found from the main Daz Site is : https://bugs.daz3d.com/hc/en-us/articles/115003568443-What-are-the-System-Requirements-to-run-Daz-Studio
But that is dated 2017.
The locked discussion threads in the forum mainly talk about known issues.
Post edited by Wahil on
  • In answer to your question, those are the minimum system requirements to run studio.
    It'll run horribly, and you'll be highly limited in what you can do, but it will mostly still work, and that's all a minimum is about.
    If you're wondering if some particular hardware you have will run studio, just post the specs and we can give you an opinion on them.
    If you're looking for recommendations for hardware, just ask and you'll get plenty of opinions.
  • jmtbankjmtbank Posts: 189
    edited June 2025
    TLDR: Any basic 32gb memory office machine* with a $200 Nvidia 3060 2nd hand graphics card added to it.  *You need to make sure a machine's power supply has a 6+2 pin power connector. I guess that power connector requirement is also an important true minimum requirement.
    In practice I personally wouldn't recommend Daz unless you are willing to punt for a 2nd hand Nvidia 3060 12GB card. This for me is a realistic minimum. And 32GB system 'DDR ram' memory.
    From reading comments on the forum people still do CPU rendering.  And if you only want to do occasional stuff and don't mind leaving your machine on half a day for a final render it can still work.  So there isn't technically a minimum.
    I had a 3060 12GB briefly in 2021 felt it was just fine for creating the type of renders you see on the shop pages. Prior to this I was using a 12 core CPU to render. And before that an 11GB 1080ti (rendered useless in 2020 by Nvidia Iray changes).
    For the computer processor - CPU; If you are rendering on a graphics card like the 3060 you don't really need more than a 4-6 core CPU. So something like an AMD 3600 or Intel 10400 or better. Ie literally the cheapest currently sold office PC is fine CPU wise. And 32gb memory.
    Post edited by jmtbank on
  • bstrain11bstrain11 Posts: 4
    Why does DAZ make all this necessary information so hard to find? I do so many searches for answers only to get a blank screen. If it wasn't for these scattered forums nothing would ever be found.
     I was thinking about getting a new machine with a NVIDIA 5070 GPU, but found bits and pieces in forums that the 5070 isn't supported by DAZ right now, but could possibly be soon.
    So, I am holding off on a new machine for now until somewhere, somehow, someway there is a forum post that says it will work.
  • LeanaLeana Posts: 13,598
    50xx cards work in DS2026, which is currently in beta.
    They are not supported for Iray rendering in DS4, and are unlikely to ever be, due to technical limitations which prevent Daz from integrating a version of Iray supporting them into the DS4 codebase.
  • Navigator_ITANavigator_ITA Posts: 84
    edited April 17
    For gpu, minimum but good: rtx 3060 12gb with genesis 8.1.
    Post edited by Navigator_ITA on
  • MadbatMadbat Posts: 392
    What is a good recommended card if 50xx aren't supported? I'm currently using an older laptop with 16Gb of ram and an RTX 3060.I'm thinking of getting a newer one.
