HLME3D Hayven LIE Tattoo Won't Show On Anatomical Elements Mat
3DSaga3DSaga Posts: 907
The product I'm having trouble with is this one: https://www.daz3d.com/hlme3d-hayven-hd-for-genesis-9
The tattoos are LIE, and all of them work nicely, except for one that spans both her torso and the G9 gens area. The tattoo shows on the torso, but the part that is in the gens area is cut off. The PA clearly intended for this to work as they include a gens mat, and the tattoo isn't cut off in the promos. What is the process to get the LIE tattoo to show in the gens area?
  • Richard HaseltineRichard Haseltine Posts: 111,382
    Are you using the Daz Anatomical Elements or another set?
  • 3DSaga3DSaga Posts: 907
    edited June 2025
    Hi Richard, I'm using the DAZ G9 Anatomical Elements.
    Post edited by 3DSaga on
  • felisfelis Posts: 6,504
    The filelist does not include materials for the genitals, and there is only 1 texture for each tattoo, so genitals are not supported.
    You could do it by changing the UV of the genitals, if you have a body UV for the genitals.
    edited June 2025
    Felis, the file list doesn't include materials for the genitals, however they're included with the product, as you can see in the attached screen shot.
    The odd thing is the tattoo in question works with another G9 gens set (Golden Palace For G9) I bought on a different site. I would really like it to work with the DAZ G9 Anatomical Elements.
    1903 x 1032 - 275K
    Strange that it isn't in the file list.
    But the filelist still only lists one texture per tattoo, so unless that also is wrong, then you can't default apply the LIE to the genitals, as the body UV doesn't match.
    That's probably accurate. None of the other tattoos involve the genital area, only this one tattoo in particular.
    As mentioned above, if needed, you can do it with UV swap
    Thanks, felis. I watched a video about UV Swap, which is a very interesting process in DS. I need to read up about it some more. One could ask why the PA didn't take care of this when they set the character up.
