dForce include-exclude objects
Is there a way to simulate only some of the objects in a scene? For example: say I have a scene with two figures, but I only want to simulate figure 1. Figure 2 would need to be involved in the collisions, but I only want figure 1 to actually be simulated.
Or do I basically have to go through the trouble of animating a scene, and animate figure 1, but leave figure 2 static?
Thanks in advance.
  • ToyenToyen Posts: 2,081
    Hello there,
    you can always 'freeze simulation' on objects that you either do not want to simulate or that are already simulated.
    Alternatively, when clickin on the dropdown menu on the top right in the simulation tab, there is a 'Simulate Selected' option that should only simulate the item you have currently selected in the scene tab.
    Hope this helps!
    Toyen
  • Richard HaseltineRichard Haseltine Posts: 111,896
    You need to select not just the things you want to behave dynamically but also anything you want them to collide with.
  • Reality HackReality Hack Posts: 111
    Thanks, guys.
