Can't Save Morph Asset in Genesis 9 (GoZ / ZBrush Workflow)
Hi,
I hope someone can help me with this issue. I've watched several tutorials on how to save morphs, and in the past, I was able to do it successfully with other Genesis figures. However, for some reason, I haven’t been able to make it work with Genesis 9, even after following the same steps.
Here’s a breakdown of my workflow so you can get a better idea of what might be going wrong:
  1. I send the figure from Daz Studio to ZBrush using GoZ.
  2. I make the necessary modifications in ZBrush.
  3. I send the modified figure back to Daz Studio, and a new morph is created (as shown in the attached image, under the name “New Body”).
  4. In the Parameter Settings, I change the minimum value of the slider to 0.
  5. Then I try to save the morph using File → Save As → Support Asset, but the "Morph Asset(s)" option is greyed out, so I can’t save it.
I also tried changing the Path field in the Parameter Settings to something like Actor/MyZBrushMorphs, but as soon as I close the window, the morph disappears from the scene. I checked the /Data/ folder but couldn’t find any related files.
Anyway, I hope my explanation was clear enough. I’d really appreciate any guidance or help to figure out what I might be doing wrong.
Thank you very much for your time and help.
1917 x 964 - 190K
425 x 819 - 65K
651 x 833 - 87K
  • LeanaLeana Posts: 13,565
    IIRC Morph asset is deprecated, you should now use "modifier asset"
  • Richard HaseltineRichard Haseltine Posts: 111,701
    Note that it is modifier asset, not modified assets
  • PatrickPatrick Posts: 18
    edited June 2025
    Thanks a lot for your reply! That really helped clear things up. I followed the steps using “Modifier Asset” instead of “Morph Asset” and it worked perfectly. I appreciate you taking the time to help out!
    Post edited by Patrick on
