Polish "The Hotel Room" Crashing
Has anyone who purchased this running into crashing issues?
For me it starts to render (IRAY) and then crashes a few minutes into it.
Its the only environment that I'm having this issue with and I tested it on two machines.
I'm running on Win10 Pro, 2x 980GTX, Daz 4.8.xx, latest Vid Drivers. Also tried older drivers!
Suggestions on how to figure it out would also be very helpfull. I really like this one!!
Thanks in Advance!
Post edited by anthony.luigi_05ebfcd7e7 on
    Exactly which build of D|S4.8 is that? I know there was at least one version that crashed when you tried to use some Iray scenes — it was fixed in the next release. Unfortunately I can't remember which version that was. So it can be important not to leave out the build numbers; always give all four parts of the full version number.
  • 4.8.0.59
  • Richard HaseltineRichard Haseltine Posts: 111,654
    4.8 did have a bug in its version of Iray that caused some products to crash. If your GPU is up to it turning the CPU off in the Advanced tab of Render Settings may help, but the real fix is DS 4.9's updated version of Iray.
  • Im very hessitant to upgrade. I don't like the stuff that I'm reading about Daz's latest move.
    If you mean Connect that is not mandatory - only a few items require it, and if you spurn those you will be no worse off than sticking with 4.8 but will ave the bug fixes.
  • If you mean Connect that is not mandatory - only a few items require it, and if you spurn those you will be no worse off than sticking with 4.8 but will ave the bug fixes.
    Will I still have all my stuff organized my way in Contenet Manager as I do now and will I be able to drag and drop my purchased stuff into My Library as now.?
    Sorry for som many questions, theres a lot of people making a big stink about this.
    Thanks for your help!
    You should export your UserData (Content Library panbe option menu>Content DB Maintenance>Export User data) as a safeguard but yes, your existing categorisation should reimport and you will be able to install using your usual methods.
