Can't find "Look At My Hair"
KN
Hello there,
I bought "Look At My Hair" to put fur on my wolf, but when I rendered the wold did not have any fur.
I looked into my products and could not find "Look At My Hair". It was installed via DAZ Install Manager.
How can I activate it?
Thank you!
_KN
Were you rendering in Iray? LaMH doesn't work (yet) in Iray, because it uses a function of the 3Delight renderer to create the hair strands. To use it in Iray, you must convert the LaMH hair groups into FiberHair, then convert the shaders applied to the hair from 3Delight to Iray.
It's on Window -> Panes (Tabs) -> Look at My Hair
You can add the tab to your regular tabs. You need to also use your serial number issued by DAZ to go to the link in the LAMH activation instructions to get a activation number and you need to input both of serial & activation into the LAMH tab. It is not activated like most DAZ plugins.
Awesome, it's working, Thanks guys!
Cheers!
