.sep files or .zip for offline install v7 for DS 4.8, can it be done?
I just purchased v7 and some other things here at work, I want to install at home which my home PC is not connected to the internet.
I'm guessing the SEP files are for 4.9 which I DO NOT want to install, DS 4.9 (I DONT use Iray), not the SEP files (What is SEP btw?)
can I use the zips from my product library to install these items to DS4.8 at home to the computer not connected to the internet?
Can I install to a computer not on line?
  • LeanaLeana Posts: 13,502
    Unless it's a product available as encrypted DAZ connect only you can indeed download the zip available in your product library from another computer and install that zip to your DS computer.
  • MelanieLMelanieL Posts: 7,867
    edited March 2016
    The .sep files are only for those using DAZ Connect - which requires 4.9 and that you connect your PC to the internet at least once to activate/validate it.
    The .zip files from your Product Library can definitely be used. You can download a DIM installer from Product Library here: http://www.daz3d.com/downloader/customer/files/#prod_14810 and take that home and install on your non-connected PC and then install all the zips through DIM - this is what I do. You do not need to connect to the internet at all with that machine.
    If you don't want to install DIM either, then you can just copy the .zip files to your home PC and install manually by moving the folders/files into the correct location - I used to do this too, before I decided to just go with DIM.
    ETA: Oh I must have spent too long typing - I see Leana beat me to it!
    Post edited by MelanieL on
  • StratDragonStratDragon Posts: 3,290
    thanks both, I'll flash the files from this computer to my home one and see how far I get.
